Re: 560 stuck in gear
Posted by Janicholson on April 03, 2010 at 15:33:56 from (64.61.211.136):
In Reply to: 560 stuck in gear posted by Pete D on April 03, 2010 at 15:23:38:
The three bolts around the lever tower will remove the lever. The tractor is stuck in 5th. with the clutch down, TA back, use a large screw driver to pull the left most shift rail (down the hole with a good light) back to alignment with the rest of them.
Welding up the tip of the shifter to resize it should be the cure. Jim
