Posted by sflem849 on April 04, 2010 at 19:40:01 from (69.197.84.192):
In Reply to: starting prcedure WD9 posted by Janicholson on April 04, 2010 at 18:02:32:
Janicholson said: (quoted from post at 18:02:32 04/04/10) That is definitive.
You are going to need to have the seals in the pump worked on. it could be literally cracked or broken. it should have engine oil only in the chamber, too the check port you mentioned. I would not try to run it any more until the pump was repaired. It might be clear what is wrong with it by taking it apart carefully on a bench, but shops might not work on it is it has been taken apart casually. (There are good diesel pump shops, I do not have a contact for a good one, the archives might provide a good source. Jim
I just got my MD injectors redone at DIS in Windsor, WI. They were very reasonable at $200 each with new valves and new everything in each. The Central Diesel guy would have been about 50% more than that, but I hear he is VERY good.
Too bad Sask is so far away, I would LOVE to have a WD-9. Bad pump or not. They are no big thing, only money. Couldn't it just be a bad lift pump seal causing inj pump dilution? That is a super cheap shot in the dark if it is a possible cause. No timing or any other stuff needed, just a $5(?) gasket.
This post was edited by sflem849 at 04:32:24 04/05/10.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
