Re: starting prcedure WD9
Posted by Janicholson on April 04, 2010 at 18:02:32 from (64.61.211.195):
In Reply to: Re: starting prcedure WD9 posted by M in sask on April 04, 2010 at 17:51:41:
That is definitive.
You are going to need to have the seals in the pump worked on. it could be literally cracked or broken. it should have engine oil only in the chamber, too the check port you mentioned. I would not try to run it any more until the pump was repaired. It might be clear what is wrong with it by taking it apart carefully on a bench, but shops might not work on it is it has been taken apart casually. (There are good diesel pump shops, I do not have a contact for a good one, the archives might provide a good source. Jim
