Re: Drawing air into the exhaust
Posted by Marty from MN on April 05, 2010 at 16:08:52 from (174.20.18.7):
In Reply to: Drawing air into the exhaust posted by Twin49Cubs on April 05, 2010 at 14:14:12:
Did you take your timing gears off?
Exhaust valves could be open on your downstroke. Check your timing marks, if they are correct, its turning backwards.
