Drawing air into the exhaust
Posted by Twin49Cubs on April 05, 2010 at 14:14:12 from (63.131.104.66):
I am wondering what I did wrong. After rewiring my 49 Cub the exhaust is now drawing air in when I try and to turn it over. I know it is positive ground and think that I rewired it correctly. A different (from another CUb) distributor was put on with new wires, new plugs, the timing was set an the valves were adjusted also. The starter switch was also swapped out and a light switch was wired into the mix after not having one prior. So what would cause it not to start and draw air in through the manifold pipe. Thanks
