I do not know what you did, but two things strike me as important. It should spin CW when standing in front of it looking at the radiator. (the fan blades pull air through the radiator, top of fan moves to the carb side. If it is spinning backwards, the only two things would be a starter from a power unit that should go on the engine side of the flywheel and face as they do in most cars which if put into the rear will spin it the wrong way, Or the starter motor has been disassembled and resoldered together wrong. All series wound motors run one way only no matter what the polarity. When manufactured, that direction is set. Jim
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
