3388 hydraulic pump, continued
Posted by haymaker421 on April 06, 2010 at 13:35:08 from (75.100.135.171):
I already posted this but now I can't find it. Anyway, the gear that drives the pump seems to be alittle sloppy and the teeth are worn. The shaft that this gear is attached to has some movement, about 3/8 of an inch. There is a collar connection on this shaft but I don't see how to move the collar so I can get the short shaft and gear out. Is there a way to move the collar so I can remove the gear and replace it?
