Re: 3388 hydraulic pump, continued
Posted by pete 23 on April 06, 2010 at 17:02:34 from (173.87.145.42):
In Reply to: 3388 hydraulic pump, continued posted by haymaker421 on April 06, 2010 at 13:35:08:
The shaft the gear is on is actually a long shaft that goes way to the front of the ta housing. You can remove pto rear unit and get the coupler off, butttttt, with out looking in manual, I don't think there is enough room to pull gear off due to interference with other components. And, the shaft will also be worn. This was a definite problem with the closed center hydraulic pump when using the pto any amount. A gear pump conversion will be much more tolerant of looseness within reason of course. It is a major job to repair correctly.
