Posted by Phillip low on April 06, 2010 at 18:22:11 from (76.107.29.1):
My Super A has two idle speeds when using the throttle control, Wide open or idle. I've removed the gov housing and other than being nasty in there, It looks ok. I then removed the magneto gov gear to inspect it for any obvious damage and noticed I cant move the gov weights. How much force does it normally take to make these things move. I did notice rust on the shaft where they touch. Also, The spring lever.....Does the part that is on the block side, Trip or engage anything? Thanks.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
