Re: Super A Govenor weights
Posted by gene bender on April 07, 2010 at 03:38:35 from (207.177.56.155):
In Reply to: Super A Govenor weights posted by Phillip low on April 06, 2010 at 18:22:11:
No the wts should not be rusty and move free. NOW that you have removed the gov assy gear how do you plan on getting it back lined up on the same teeth it was. If you clean up the wt side of the gear you will see two dots on a tooth. That is a timing mark and the cam gear has the same two dots. You will need to turn the engine over till you can see them on the cam gear. Now you can replace the gov gear with those dots aligned on each other. When turning engine over you will see a single dot on the cam gear that one lined up on the crankshaft. Just make sure you find the two dots. You should maybe purchase an I@T manual as it will have a pic of the timing marks as i have described. good luck as your engine will not start until you get the dots aligned.
