Re: Farmall 100
Posted by Andy Martin on April 07, 2010 at 09:14:24 from (199.197.2.156):
In Reply to: Farmall 100 posted by J. Thacker on April 06, 2010 at 18:13:24:
Are you sure the battery is hooked up negative ground? If the PO just swapped batteries he may have left it positive ground not knowing the starter works either way.
Charging the battery backwards is about the only thing that will blow the acid out and burn up the generator in short order. That would also account for the high charge rate.
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
