Re: IH 574 Three Point Lift Problem
Posted by JimB2 on April 07, 2010 at 18:40:27 from (99.240.236.11):
In Reply to: IH 574 Three Point Lift Problem posted by Richie Magoo on April 03, 2010 at 22:04:48:
Richie, The recommended hydraulic fluid is CIH Hytran fluid. There has been several discussions on this board about Hytran and equivalents, so search the archives about Hytran. My brother has used the EXXON equivalent for years without problems. I don't know what to suggest to flush out the trans/hydraulic system. The problem is that even if you drain the system there is still about a gallon or more in parts of the system that don't drain. I do believe putting a magnet in the filter canister by the screen should help collecting the metallic bits. Probably take another couple of filter changes to cleanup the sytem.
Good luck
JimB
