White exhaust from H
Posted by Dave in CT on April 08, 2010 at 17:54:58 from (69.182.72.124):
I"m getting some pretty significant white exhaust smoke from my 49 H. I've done a compression test and all cylinders check out OK - 118 - 123 lbs is the spread. I'm wondering if one of the possibilities (or a _likely_ possibility) is a compromised head gasket. I haven't drained the oil yet. It's been six month's of very occasional use since it's been changed but for long enough periods it should have cleared any moisture that would have collected due to the weather. Extended runs reduces the white smoke a bit but it does persist and get thick with throttling up. There is a little blue in occasionally but the majority of the exhaust is white. What will be my next diagnostic steps to verify it's the head gasket? What's involved to correct it? Thanks for your time.
