Re: partially wired H for 12 volt.
Posted by Janicholson on April 09, 2010 at 11:51:39 from (199.17.6.222):
In Reply to: partially wired H for 12 volt. posted by lspencer001 on April 09, 2010 at 11:31:22:
It ia the same just use 12 volt bulbs in the same sockets. For bright light, it will be necessary to use a light relay (about 15 amp capacity) to switch the lights due to excessive current through the existing switch and its wire wound resistor. Jim
