Re: partially wired H for 12 volt.
Posted by lspencer001 on April 09, 2010 at 12:32:54 from (24.164.70.48):
In Reply to: partially wired H for 12 volt. posted by Janicholson on April 09, 2010 at 11:51:39:
Janicholson said: (quoted from post at 11:51:39 04/09/10) It ia the same just use 12 volt bulbs in the same sockets. For bright light, it will be necessary to use a light relay (about 15 amp capacity) to switch the lights due to excessive current through the existing switch and its wire wound resistor. Jim
ok thanks.
