Re: Re: 140 generator - please help?
Posted by Pete in PA on May 26, 2000 at 08:19:43 from (134.192.209.158):
In Reply to: Re: 140 generator - please help? posted by Dan 130 on May 25, 2000 at 19:18:54:
Which terminal is the armiture terminal? It's not well marked, and the manual doesn't explain it well. Also, I should short it while running, ya?
thanks
Pete in PA
Post A Followup
: Re: Re: Re: 140 generator - please help?
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
