Re: Re: Re: 140 generator - please help?
Posted by Bob M on May 26, 2000 at 10:17:16 from (192.232.120.194):
In Reply to: Re: Re: 140 generator - please help? posted by Pete in PA on May 26, 2000 at 08:19:43:
On my H, if you look at the generator from the pulley end and with the terminals on top, the armature terminal will be the one on the right.
Or if you have a multimeter, do this: Disconnect both wires from the generator. Then measure the resistance from each terminal to the generator frame. The terminal showing the lowest resistance will be the armature terminal.
Hope this helps....
PS - The motor does not need to be running when you polarize the generator.
Post A Followup
: Re: Re: Re: Re: 140 generator - please help?
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
