656D
Posted by Montana Rancher on April 12, 2010 at 11:26:49 from (216.14.252.198):
Well it was time to fire up the 656D after it sat all winter. The
tractor started right up however after doing some light field work
the engine started acting sluggish and slow to respond to the
governor. Went back to the shop and put in two new fuel filters and
still the same sluggish response. I am thinking it may be time to
overhaul the fuel injection pump. Am I thinking correctly? The
engine kinda of boggs down then speeds past the initial rpm
setting before it settles back down. Is there something else I
should be looking at?
