Posted by pete 23 on April 12, 2010 at 16:36:13 from (173.87.145.42):
In Reply to: 656D posted by Montana Rancher on April 12, 2010 at 11:26:49:
I would agree with fuel flow from tank, if that is good, check it at hose going into pump as those hoses deteriorate and collapse, if that all checks good, you may have fuel return restriction caused by govenor flex coupling failure. Couple ways to check for this, take timing cover off side of pump very cautiously and observe any small little black pieces of plastic. Or, take out all fittings on fuel return on top of pump and see if it runs ok then. Pump shop will talk you into a complete overhaul of pump and injectors of course. Normally just a few high rate wear parts are needed and new gaskets and seals.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
