C coolant in oil
Posted by Dale L on April 12, 2010 at 15:38:21 from (184.60.59.195):
Well I went to service a "C" I got last fall and when I drained the oil there was some anti-freeze[small amount] in the engine oil. So what would be the next step? I'm thinking about dropping the oil pan and presure testing the radiator to see if I can tell where the coolant is coming from. I was just wondering if there was a common problem with the "C" models that I should look at first? Thanks Dale
