Posted by Andrew Z on April 12, 2010 at 16:06:23 from (64.252.148.52):
In Reply to: C coolant in oil posted by Dale L on April 12, 2010 at 15:38:21:
could be a few things, cracked block or head. But the most common by far is the O rings at the bottom of the cylinder sleeves. They commonly dry out leak into the crank case. Pull the pan and see if you can see rust streaks coming down, also put a piece of cardboard under it and look for drops of water.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
