Re: 1568 pto
Posted by Owen Aaland on April 12, 2010 at 20:40:53 from (65.165.246.221):
In Reply to: 1568 pto posted by BradinPA on April 12, 2010 at 20:25:22:
The linkage that attached to the adjusting nut has to over center on the cam assembly that is pulled up by the rod going to the operating lever. There is also a spring to hold it in either the engaged or disengaged position. Make sure the top of the link goes past the pivot on the cam and that the spring is attached between the bottom of the rod and the access hole for the pressure check plug.
