Re: H won't start with spark
Posted by Dan G on April 13, 2010 at 04:04:13 from (208.111.212.26):
In Reply to: Re: H won't start with spark posted by Bob M on April 12, 2010 at 19:23:13:
I have a compression tester. What should be the compression psi? I will try the "oil trick" today , hopefully.
