Re: H won't start with spark
Posted by mkirsch on April 13, 2010 at 05:09:17 from (64.80.108.57):
In Reply to: H won't start with spark posted by Dan G on April 13, 2010 at 04:04:13:
Dan G said: (quoted from post at 04:04:13 04/13/10) I have a compression tester. What should be the compression psi? I will try the "oil trick" today , hopefully.
I'm thinking anything over 80PSI will start fairly well. 100PSI is good. 125PSI is great. When you start getting down into the 60-70 range it's time for a rebuild.
How is it cranking over? If it's just barely rolling over, it may not start after sitting for so long.
Are you using the choke? Too much or not enough can cause a tractor to not start, but each tractor is different.
Are the plugs wet when you pull them after cranking for a while?
