Re: 140 generator - please help?
Posted by Jamie on May 26, 2000 at 17:30:49 from (24.218.208.40):
In Reply to: 140 generator - please help? posted by Pete in PA on May 25, 2000 at 18:36:43:
Yes, it could be that your generator is not polarized, especially if you have disconnected the battery and/or ground lately. To repolarize (while ignition is on but tractor doesn't have to be running) connect a jumper between the BAT terminal on the regulator and the A terminal of the generator. Just touch it briefly, there should be a small spark. BAT is the middle lead on the regulator, A should be the terminal farthest away from the engine and should be stamped into the metal.
You should also clean the commutator on the generator with sandpaper. this can also prevent charging if it has crudded up.
However, you should seriously think about converting to an alternator, much more reliable.
Post A Followup
: Re: Re: 140 generator - please help?
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
