Re: more super a plow set up
Posted by ih560 on April 15, 2010 at 13:51:24 from (67.131.50.233):
keith49 sa said: (quoted from post at 04:51:21 03/26/10) hi everyone. i now have the plow all mounted and built a temperary draft arm but i am still haveing trouble geting it to dig in good. i was wondering how long should be? and my draw bar also apears to be bent about 1"-2" down on one side. could this be giveing be a problem? it seems to want to start slideing off to the left when i try to pull it in harder ground instead of diging in. thanks agin guys for the help and pics been a big help.
Here is the factory bar on my Super A. You can see how long it is and exactly how close the drawbar is to the ground, when the front lift is lowered all the way down.
third party image
third party image
I just plowed with this a month or so ago and it did very well, going into the ground and turning it over. It did take about 3 passes before it was plowing good and deep.
