Re: H Starting Problem
Posted by Janicholson on April 18, 2010 at 05:19:01 from (64.61.211.130):
In Reply to: H Starting Problem posted by Doug Kieta on April 17, 2010 at 14:41:01:
If there is fuel to the carb inlet port (fuel runs out like a small soda straw) (there is a screen at that fitting!)
If you have the Idle ports and main jet clean (it is not the load screw on the front bottom, that adjusts the total main fuel within a range of richness, the main jet is inside)
If you have the choke plate working.
If you have fuel in the float bowl.
If it runs on supplemental fuel.
If the carb gasket at the manifold is good.
If when you hold your hand over the inlet and crank, it floods gasoline back out the inlet (it should) If none it is not getting fuel from the carb.
It will start and run! Jim
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
