Re: 400 gas IPTO problem
Posted by Owen Aaland on April 18, 2010 at 20:37:23 from (65.165.246.74):
In Reply to: 400 gas IPTO problem posted by BenB on April 18, 2010 at 20:02:23:
It may be that water has collected in the hydraulic oil and settled in the area of the seasonal disconnect lever causing it to rust tight.
Drain the oil and remove the cover. You then will be able to determine whether it is rust or some problem with the disconnect assembly.
