The arm on the right doesn't control lift. It tilts the angle of the hitch beam for depth control with the plow.
With the depth control lowered all the way down in front, it raises the rear of the hitch, and consequently whatever's hitched to it. It might be enough to bring the plow out of the ground. Normal transport position on the plow is only about 3" off the ground. Otherwise you wouldn't be able to lower it far enough to plow deep.
On the left side, are you sure you have the correct linkage? These were often abused, bent, ruined, and replaced with homemade pieces. The correct linkage should have some adjustment at the rear end with a nut.
Also, is your touch control working properly? Is it moving through the full range of motion? Does it have adequate power to lift the disk/plow (i.e. it's not stalling out before reaching full travel with the weight of the disk/plow on it)?
If you can determine that your touch control is working properly, then go ahead and do what you need to do to shorten the left linkage and gain yourself a little lift.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
