Re: Farmall 140, fast hitch wont pick up high enough?
Posted by Haas on April 19, 2010 at 05:45:00 from (75.254.117.177):
In Reply to: Farmall 140, fast hitch wont pick up high enough? posted by OB OBrien on April 19, 2010 at 04:44:38:
If all the parts are there, both lift links at the rear are adjustable. It sounds like you may be missing the arm in front that goes from the front of the "bail" to the front rockshaft arm on the right side of the tractor. That moves the front of the bail up and down and tilts it so the rear lift will be higher. If you don't have that and the front of the bail is attached under the floor pan, your plow won't work anyway. The front of the bail has to be tilted down to get the plow to go in the ground.
