Pull this plug on the housing. Behind it you will find the center section with the shuttle valve cover plug looking you in the face.
Remove the smaller center section plug and fish that broken snap ring, the valve, 2 flat washers and its spring out of the hole.
If it doesn't come out in pieces, I'm wrong, but sure don't think so. :>)
Anyway, go to the hardware store and get yourself another 3-cent snap ring. You'll see how it should all fit together with a flat washer on each side of the spring.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
