I hope for his sake you are correct on your diagnosis, that being said, I have had several hydros apart, never once did I find that to be the problem. Had stuck shuttle valves, plug fell out on end of shuttle valve causing a lurch problem, several worn lever mechanisms causing drive to stop midway into range and a host of simple to complete trashed units. I would suspect something in the speed ratio cam or orfices or servo cylinders myself and would do a pressure test on the servo circuit but, there are a million things that can and do happen inside these units. For the most part, they are very reliable with good clean fluid and filters changes.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
