Re: Hydro question for Allan in NE
Posted by Owen Aaland on April 19, 2010 at 15:41:36 from (65.165.246.74):
In Reply to: Hydro question for Allan in NE posted by Dave from MN on April 18, 2010 at 06:36:59:
The symptom of a broken snap ring is usually from neutral the tractor will not move when you move the lever into the forward position or the hydro will suddenly engage at the speed position where the lever is set. If you go from neutral into reverse and then into forward the hydro will work as normal.
In my experience of sudden failures the three main causes were, snap ring of shuttle valve, stuck high pressure relief valve, and a crack in the flare of a jumper tube. They seemed to be about evenly divided as to which occurred most often.
