Re: Farmall Super A Wheel Rim Issue
Posted by Mr. Dan on April 19, 2010 at 16:08:01 from (64.136.173.16):
In Reply to: Re: Farmall Super A Wheel Rim Issue posted by Erik Dekeyser on April 19, 2010 at 15:08:44:
Thanks, Erik. I have no desire to try to chase down a good original. I needed you to tell me I had the right wheel! So I need a round-headed carriage bolt whose square sub-head fits down into this new lug, big enough not to turn and with enough length to compensate for not dropping down into the square hole in the original, right?
I can do that.
Thanks again,
Dan
