The new rims are all like the one you got. If you want original, you can buy a bare rim and the cast lugs and rivets (or reuse your old lugs). I would not use carriage bolts with your new rim. Instead, I'd go get some grade 5 or 8 hex head bolts and washers and use those. With that, you can use a wrench on both end to tighten the bolt and not worry about it turning. The loop setup on your new rims is like most all newer tractors.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
