Re: Farmall Super A Wheel Rim Issue
Posted by gene bender on April 19, 2010 at 17:33:58 from (207.177.56.155):
In Reply to: Farmall Super A Wheel Rim Issue posted by Mr. Dan on April 19, 2010 at 14:43:10:
With the new rim the carriage bolt will work j ust fine as the loops arent like the original. Most of the time the old rim needs to be sandblasted and repainted. What size tires are you using and did you get the correct size new rim.
