Posted by John T on April 22, 2010 at 06:50:53 from (66.244.97.31):
In Reply to: Re: H Ammeter Hookup posted by Janicholson on April 22, 2010 at 06:08:27:
Yo Jimbo, I agree with you and myself lol Yep a direct battery connection to the FLD terminal causes a very high current to flow through the field relay contacts which normally switch only a few amps. However if they welded shut as you mentioned (and no other harmful affects) that should make her always charge at high charge similar to when we dead ground the FLD for diagnostics YET SHE SHOULD STILL CHARGE (if all else okay). BUTTTTTT if the current (when he jumped FLD to BAT) was too high it may have burned the field circuit OPEN thereby the gennys Field NEVER sees the ground needed to charge, Id say thats more apt to be what ruined the VR (a burned open winding) then its contacts got welded shut, although either still ruins the VR and BOTH may have resulted........Im only saying if all that happened was the contacts welded she ought to still charge but if the winding also opened NO CHARGE, NO TICKY NO LAUNDRY LOL
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
