Re: Timing J4 Mag to Engine
Posted by El Toro on April 23, 2010 at 09:37:03 from (74.103.74.58):
In Reply to: Timing J4 Mag to Engine posted by 47H on April 23, 2010 at 07:36:54:
Did you have the No1 piston at TDC on the compression stroke before you installed the mag?
You need to do this and see where your rotor is pointing. Hal
