Timing J4 Mag to Engine
Posted by 47H on April 23, 2010 at 07:36:54 from (76.164.179.49):
1948 Cub. Just recieved newly reconditioned J4 mag. Following instructions in Original Cub Owners manual page 32. I have turned mag impulse coupling until the rotar arm points toward the No.1 terminal on the distributor cap. Then assembled the mag on the engine making sure the lugs on the impulse coupling engaged the slots on the magneto drive coupling and rotated mag as close to the block as possible. I then cranked the engine 1 complete turn until top dead center again. Then as the book instructs, I rotated the mag away from the engine block waiting for the impulse coupling to click. I moved it as far as it will go and NO CLICK. I know it is working because when I rotated the crank it clicks. Just not where the book says it should. Suggestions please!!!! Thanks
