It could be stuck in two gears. Can you shift the gears? If so ignore the rest of this post. I looked at a non-running 350 row crop yesterday. Transmission appeared to be in neutral, but I could not get it in any gear, clutch in or out. TA had no effect. Did not try to push it because pushing 4500 lbs plus with a flat tire is hard to do. With it jacked up, wheels normally turn in opposite directions. I think that it is in 2 gears, and that the TA should have no effect. Try removing the shift lever and see it you can move the rails with a screwdriver.
Today's Featured Article - Maintaining Rubber Tires - by Staff. The broad use of rubber tires on farm tractors and machinery has resulted in a great saving in both time and operating costs since the time of steel wheels. There are, however, certain basic fundamentals in the care of tires that should be followed carefully if the owner is to derive maximum benefit from his or her investment. First and most important is to maintain proper pressure for the work at hand. Your best guide to proper inflation is the operator's manual or instruction book tha
... [Read Article]
Latest Ad:
[More Ads]
