IH 300 Torque amplifier
Posted by Chris Klein on April 24, 2010 at 06:01:44 from (162.40.4.211):
I just dragged home a 55 IH 300 utility in non running condition. The problem I am having right now is that it will not roll unless the clutch is pushed down. All it will do is the rear wheels will turn in opposite directions as if it was in gear. Also the engine will not turn unless the clutch is pushed down. All I have been told is that the pnly two problems when it was parked is the T/A had not worked in quite some time and that the hydraulic pump was leaking pretty bad. Could the T/A be causing this ? I am not familiar with the T/A tractors and appreciate any advice
Today's Featured Article - Maintaining Rubber Tires - by Staff. The broad use of rubber tires on farm tractors and machinery has resulted in a great saving in both time and operating costs since the time of steel wheels. There are, however, certain basic fundamentals in the care of tires that should be followed carefully if the owner is to derive maximum benefit from his or her investment. First and most important is to maintain proper pressure for the work at hand. Your best guide to proper inflation is the operator's manual or instruction book tha ... [Read Article]
