rh rear wheel on my A
Posted by RICK in Vermont on April 25, 2010 at 15:13:21 from (71.169.187.135):
I am trying to remove the (Heavy) cast iron RH rear wheel on my Farmall "A" tractor. I haven"t used heat and don"t want to if I can avoid it. I have put a lot of Blast penetrating fluid and a lot of WD40 and have tap-tap-tapped forever and it just won"t let go. Is there something I"m missing or need to do that I don"t see Does anyone have any suggestions?
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
