Re: rh rear wheel on my A
Posted by old on April 25, 2010 at 15:52:33 from (4.245.14.188):
In Reply to: rh rear wheel on my A posted by RICK in Vermont on April 25, 2010 at 15:13:21:
Does the tractor run and drive?? If it does loosen up the bolts just a little bit and then drive it in a figure 8 and doing that should make it pop off. Just do not loosen to to much or you can brake the bolts/studs and end up with the tractor on its side
Today's Featured Article - Talk of the Town: Repairin a Gas Tank - by Staff. This interesting discussion is from the Tool Talk Discussion Forum. Remember that safety is your first priority - make sure you know what you are doing before attempting a potentially dangerous activity! ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
