Re: W450 D Clutch
Posted by mkirsch on April 27, 2010 at 05:16:11 from (64.80.108.57):
In Reply to: W450 D Clutch posted by Terry Harnett on April 26, 2010 at 21:15:00:
Making sure everything is adjusted properly is good preventative maintenance, but when a clutch won't engage, or won't release, there's nothing you can adjust to change that.
Odds are the clutch disk has rusted to the flywheel from lack of use. If it's not rusted too badly, driving it around with the clutch pedal held down, and hitting the brakes will generally break it free.
