Re: M vs Super M Block
Posted by Janicholson on April 27, 2010 at 17:51:37 from (64.61.211.116):
In Reply to: Re: M vs Super M Block posted by Bouncer on April 27, 2010 at 17:46:22:
The M Flywheel will bolt on the SM crank. The blocks are interchangeable. The M clutch is a little less grippy than it needs to be for a SM engine. Thus the better clutch (to fit an M FW) Jim
