Posted by Bouncer on April 27, 2010 at 17:46:22 from (68.28.138.228):
In Reply to: Re: M vs Super M Block posted by Janicholson on April 27, 2010 at 17:40:20:
I am a little confused. You say the M clutch and flywheel are smaller and will not work on the SM engine. Then you say to use the M flywheel and a different clutch disk and it will work.
So will the M flywheel work on SM engine? If the flywheel works why does the clutch disk not work? Getting an aftermarket clutch is not a problem, just curious as to if I am understanding you correctly.
Today's Featured Article - Fabrication (Who Me? Make it myself?) - by Chris Pratt. First of all, what are the reasons for not fabricatin your own parts? Most judgements on what should be purchased rather than fabricated stem from: Originality - If the tractor restoration is to be 100% original, it is likely that you should spend the time and money to locate the component in the used or New-old-stock market. Since this can be extremely difficult, you may want to fabricate the item or purchase a modern replacement temporarily, but eventually, you s
... [Read Article]
Latest Ad:
[More Ads]
