Re: M vs Super M Block
Posted by Owen Aaland on April 27, 2010 at 18:02:48 from (65.165.246.74):
In Reply to: M vs Super M Block posted by Bouncer on April 27, 2010 at 17:33:26:
The M uses an 11 inch clutch and the Super M a 12 inch clutch. As long as the clutch matches the flywheel it will all fit either way.
