Re: Gene Bender ..others...need cultivator help for BN..
Posted by gene bender on April 28, 2010 at 11:37:32 from (207.177.56.155):
In Reply to: Re: Gene Bender ..others...need cultivator help for BN.. posted by gene bender on April 28, 2010 at 11:21:12:
You will have to drill the holes for the front sections as they are spaced different than the holes on the B. Where do you live as i sure would trade as i have a B that someone Used SC parts and put it on a B rite down to the controls for the hy system used a SC bellhousing Block moved the steering post to a battery box they made did a great job Now i need a cult for a C. Looks like your rears are for the B. So do you have the lever on the drivers platform to lift the rears also.Those fronts will lift hard by a hand lever you need the lift lever for the two-way moldboard plow as it would lift the left side then you need a lever tha will lift the right side. I dont see the levers you now have will work as they are for the B,BN. Give me a call as i think we can make those work with some different rework. 319-430-3907 I live in Iowa we are on CST.
