Correct way to install pan gasket
Posted by Gordy from Iowa on April 28, 2010 at 15:16:27 from (75.167.210.207):
Pan gasket was leaking oil on my Farmall 350. Pulled the pan off today and it appeared that the front left corner was leaking. It was a cork gasket that was pasted to the pan, but not to the engine side. Is this the right way?
I'm picking up a new gasket tomorrow from the IH dealer. Do I "butter" one side or both? And, how much torque on the bolts? What is the best brand of gasket sealer to use? Sure would appreciate the advice any of you guys have.
