Posted by Wilamayb on April 30, 2010 at 14:04:06 from (71.15.148.196):
We have done some work on a 47 H that had been sitting in a barn for arond 30 years.
It was very farmer engineered. We have repaired most of the engineering and have done some work on the engine.
It now runs very smoothly and has great power but will not idle down. After more looking and pilfering I surmised that someone else has had this issue as the governor linkage it totally out of adjustment (the one underneath the little cover with the metal tube coming out the top going to the front of the cylinder head) in the direction that I would need to adjust it.
The question is... What is worn or missing that would cause it almost, but not quite return to idle? I can push down on that linkage that goes vertical through the governor housing and make it slow down but then its speeds back up when I let off.
Even with the throttle handle removed and the linkages pushed all the way in the idle position it still idles too high.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
